cant figure out the problem!!!
  • Thread starter Thread starter superspec
  • Start date Start date Feb 3, 2010
superspec
78
  • Feb 3, 2010
ok, so ive searched and still cant find the answer to my symptoms.
last week while driving down the road i noticed a weird feeling while cruising on a flat street. the feeling is like trying to drive 20mph in 5th gear, the whole jerky, milkshake feeling. at the next redlight i realized my rpm was down to about 600 and it sounded like i have a big cam. on cold startup the car wont idle at all and while warm the idle bounces between 600 and 1000. and lastly its running really rich.
things i have checked for: broken or loose vaccuum lines ( visual and with trotle body cleaner) timing was dead on at 10* with the spout unhooked, plugs are fine, wires fine, and there is no miss.
i actually like the sound, but hate the drivability! can somebody please tell me where to look next!!!
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Feb 3, 2010
  • Feb 3, 2010
I think it could be your idle control valve or your tps sensor so check those out because if your idle control valve is dirty or is bad or your tps is set wrong or it's just bad it will cause the same problems you're having so check those out. GOOD LUCK
superspec
78
  • Feb 3, 2010
i thought about the IAC but ruled it out because of holding an idle semi steady. in my experience a bad IAC will cause wild swings. i didnt however think of the TPS.
thanks
anybody else have an idea?
SpartaPerformance
2,517
61
89
Long Island NY
Feb 3, 2010
  • Feb 3, 2010
I'ld start with IAC too. After that I'ld check ignition wire and for burned plugs.
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
KNOCK WITH CLUTCH OUT
  • Scwhitten
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
