Can't find a code list, trouble codes, running rich.
  • Thread starter Thread starter seijirou
  • Start date Start date Aug 6, 2008
seijirou
2,417
DFW
Aug 6, 2008
  • Aug 6, 2008
Either it's not a sticky, not posted, or I'm blind, but I've been searching for 2 hours and I can't find a list of codes for a fox. I found several for OBDII though!
We have a lot of great stickies, but I don't actually see one for pulling fox codes and what the numbers mean once you have them!
Can anybody point me in the right direction.
FWIW, right now KOEO I have
81 - i think failed air management circuit 2
82 - i think failed air management circuit 1
84 - i think egr solenoid fail
95 - i think secondary fuel pump circuit, pcm to ground
KOER I have
21 - i think coolant temp, probably wasn't warmed up
26 - i think MAF out of range - may ultimately be what I'm looking for
42 - maybe O2 sees rich?.. but i can only find this for a 2.3 turbo.
92 - can't find it
33 - can't find it
oddly enough, 33 came after 93 in the KOER test.
What's the problem? I'm getting ~ 9 miles to the gallon, running so rich the fumes sting your eyes and make you nauseous.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 6, 2008
  • Aug 6, 2008
Fix the code 21 and 26 and the code 42/92 will probably go away.
Fix the code 84 and the code 33 will probably go away
Code 21 – ECT sensor out of range. Broken or damaged wiring, bad ECT sensor.
Note that that if the outside air temp is below 50 degrees F that the test for the
ECT can be in error.
The ECT sensor has absolutely nothing to do with the temperature gauge. They are
different animals. The ECT sensor is normally located it the RH front of the engine in
the water feed tubes for the heater.
The ACT & ECT have the same thermistor, so the table values are the same
ACT & ECT test data:
Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate
readings.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is
a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower
intake manifold, the voltage readings will be lower because of the heat transfer.
Voltages may be measured across the ECT/ACT by probing the connector from
the rear. A pair of safety pins may be helpful in doing this. Use care in doing it
so that you don't damage the wiring or connector.
Here's the table :
50 degrees F = 3.52 v
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
212 degrees F = .47 v
230 degrees F = .36 v
248 degrees F = .28 v
Ohms measures at the computer with the computer disconnected, or at the sensor with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
212 degrees F = 2.07 K ohms
230 degrees F = 1.55 K ohms
248 degrees F = 1.18 k ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring Mustang FAQ - Engine Information
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
Code 26 - Mass Air Flow out of range – MAF
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
Look for 12 volts across pins A & B.
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Code 42 & 92 (engine running) System rich - Fuel control or (memory) System was rich for 15 seconds or more (no HO2S switching) - Fuel control. Look for leaking injectors, fuel pressure too high, cylinder(s) not firing due to bad ignition.
Code 42 is the RH side sensor,
Code 92 is the LH side sensor.
Testing the O2 sensors
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
There is a fuse link for the O2 sensor heater power. According to Ranchero50, it is in the wiring near the passenger side hood hinge. Measuring the voltages will give a clue if it has shorted to the O2 sensor signal lead. The O2 sensor voltage should switch between .2-.9 volt at idle.
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal flickers. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1.5 ohm.
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve
apply 5in vacuum to the valve.
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect vacuum gauge to the hose coming off of the EGR Valve
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 2-5 in vacuum?
if not, check for manifold vacuum at the EGR vacuum valve.
if you have manifold vacuum then connect vacuum gauge to the EGR valve side of the vacuum valve and snap throttle to 2500 RPM.
should read about 2- 5 in vacuum
The operation of the EGR vacuum regulator can be checked by using a test light applied across the wiring connector. Jumper the computer into self test mode and turn the key on but do not start the engine. You will hear all the actuators (including the EVR vacuum regulator) cycle. Watch for the light to flicker: that means the computer has signaled the EGR vacuum regulator successfully.
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
With the with the ignition on, look for 12 volts on the red wire on the solenoid connector. No 12 volts and you have wiring problems.
With the engine running, stick a safety pin in the LT Green/Black wire for the solenoid valve & ground it. That should turn the solenoid on and cause air to flow out the port that goes to the pipe connected to the cats. If it doesn't, the valve is bad. If it does cause the airflow to switch, the computer or wiring going to the computer is not signaling the solenoid valve to open.
Putting the computer into self test mode will cause the solenoid valve to toggle. If you listen carefully, you may hear it change states.
Code 82 – Secondary Air Injection Diverter Solenoid failure AM1. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Red/White wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the Red/White wire for the solenoid valve
With the engine running, stick a safety pin in the Red/White wire for the solenoid valve & ground it. That should turn the solenoid on and cause air to flow out the port that goes to the pipe connected to the heads. If it doesn't, the valve is bad. If it does cause the airflow to switch, the computer or wiring going to the computer is not signaling the solenoid valve to open.
Both 81 & 82 codes usually mean that some uneducated person removed the solenoid control valves for the Thermactor Air system in an attempt to make the car faster. It doesn't work that way: no working control valves can cause the cat converters to choke and clog.
Code 84 EGR Vacuum Regulator failure – Broken vacuum lines, no +12 volts, regulator coil open circuit. The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70 Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches the ground on and off to control the regulator solenoid.
Code 95 Key On, Engine not Running - the following test path is for 86-90 model Mustangs.
The 95 code is because at one time or another, the fuel pump relay hiccupped and didn't provide power the pump when the computer told it to run. Sometimes this is a one time thing, other times it is a no run or runs poorly condition.
To help troubleshoot the 95 code, follow this link for a wiring diagram http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
Using the diagram, check the red/black wire from the fuel pump relay: you should see 12 volts or so. If not, check the inertia switch: on a hatch it is on the driver’s side by the taillight. Look for a black rubber plug that pops out: if you don't find it, then loosen up the plastic trim. Check for voltage on both sides of the switch. If there is voltage on both sides, then check the Pink/black wire on the fuel pump relay: it is the power feed to the fuel pump. No voltage there, check the Orange/Lt blue wire, it is the power feed to the fuel pump relay & has a fuse link in it. If there is good voltage there & at the Pink/black wire, swap the relay.
Some Mass Air conversions neglect to run the extra fuel pump wire, and they always have a 95 code. See MAF - Mustang Mass Air Conversion - StangNet - The Mustang Network for more information on the Mass Air wiring conversion.
seijirou
2,417
DFW
Aug 6, 2008
  • Aug 6, 2008
Thanks JR, tells me what I need to know
I don't suppose there's a chance I can read all your tidbits for all the codes is there?
seijirou
2,417
DFW
Aug 8, 2008
  • Aug 8, 2008
What would cause MAF signal voltage to be high?
I'm getting ~ 1.3 volts at idle, on 3 different MAF sensors. 2 stock sensors, and 1 stock sensor in an aftermarket housing.
Because all 3 gave basically the same reading, I don't think it's bad sensors.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 8, 2008
  • Aug 8, 2008
The sensor is not compatible with the housing. The MAF body and sensor are designed to match each other. Therefore you can't swap sensors between different part number MAF bodies and maintain proper calibration. The assembly is designed to match the computer’s internal program, and swapping a different MAF can upset the computer's calibration
What kind of MAF body are you using?
seijirou
2,417
DFW
Aug 8, 2008
  • Aug 8, 2008
Two of the meters and bodies are stock. The other one, I'm not sure the make, it's a black plastic body, with a stock MAF in it, which isn't the best idea because of what you stated above. However, lady luck being as she is, it's very damn close to the output of the bone-stock MAF+BODY.
The 2 stock meters read between 1.26 and 1.32 at idle, idle is about 550 rpms and stumbly because it's so rich.
The 1 aftermarket body reads between 1.3 and 1.35, also at about 550 stumbly rpms.
This is between pins C and D on the MAF.
Between B and A I get 14.1x volts, also between A and Ground I get 14.1x volts. At 750 rpms or so that voltage climbs to 14.3x.
Resistance from pins C and D to ground seemed to be good, but I'm not even sure I checked that right. I still want to leave everything hooked up when I run that test right?
I was not able to check resistance across the signal and signal return wires (C & D) yet, but I'm going to try to get that done tomorrow. However, I seriously doubt that's a problem, if it's over 2 ohms that could only lower the voltage, and mine is way too high.
seijirou
2,417
DFW
Aug 8, 2008
  • Aug 8, 2008
I should add, this hardware worked and worked well in this car before. It just suddenly stopped running leaving me on the side of the road. The only way it would run, is if I unplugged the BARO sensor. After doing that, it runs but very rich. The BARO sensor was replaced however there was no change and it still runs very rich.
That's when I pulled codes, and now I'm looking at a MAF meter output that is way too high, and I have no idea why.
Right now I don't even have the MAF meter plugged in because it runs better guessing without it.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 8, 2008
  • Aug 8, 2008
The stock MAF has a 55 MM opening and a screen. The MAF sensor is a e9zf-12b579-aa. I cannot find any part numbers on the MAF housing.
seijirou
2,417
DFW
Aug 10, 2008
  • Aug 10, 2008
I can't find a number on the housing either.
The part number for the sensors I have all match yours.
The 3rd MAF I used had an F1 part number, but it behaved the same.
The 2nd row of figures is AFH55-03
On the 3rd row of my first one I have 8m20
On the 3rd row of my second one I have 8g18
Get this, with KOEO, I have 1.09 volts between C and D. I would say I have a resistance drop on the MAF, but it's the same on all 3 of them, which work fine in a test vehicle.
I'm starting to think it's the computer.
I'm trying to think if there's any scenario or situation that would cause the computer to step up the voltage to the MAF intentionally.
seijirou
2,417
DFW
Aug 11, 2008
#10
  • Aug 11, 2008
  • #10
Well it would appear I've stumped the world with this one.
I'd rather not shell out for a new computer because I'm not convinced that the computer is the problem, although I can't come up with any other answer.
I've decided however to use this situation to test something that I've been meaning to test for some time, which is to place a rheostat in the MAF circuit to adjust the A/F ratio.
We'll see how it goes
TTSaleen05
115
Louisiana
Nov 1, 2019
#11
  • Nov 1, 2019
  • #11
So what was the fix?
General karthief
Mod Dude
Aug 25, 2016
28,143
10,764
213
polk county florida
Nov 1, 2019
#12
  • Nov 1, 2019
  • #12
Well the member has not been around since 2011 we may never know
TTSaleen05
115
Louisiana
Nov 1, 2019
#13
  • Nov 1, 2019
  • #13
It sucks that no one follows through with their fixes, I’m in the same situation and it could’ve been so helpful.
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Nov 1, 2019
#14
  • Nov 1, 2019
  • #14
I know him. He went Megasquirt. Also changed jobs a couple times forcing several moves, so car work is secondary.
Haven't seen him on any of the forums, lately.
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
P
CEL light on and Can't pull KOER codes.
  • psfoxstang
  • May 7, 2024
Fox 5.0 Mustang Tech Jun 20, 2024
psfoxstang
P
