does anyone know any tricks to getting these bolts loose, i used a pipe on the end of the wrench and i still couldnt get them loose. please help!!
I have not tried them for anything that tight, but I have had very good luck with Bolt-outs from Sears. They saved me a couple times.BlackLX5.0 said:My bolts that holds the driveshaft to the rearend, the heads of mine are stripped, How can I get them off ?![]()
You'll probably have to cut/grind the heads off, and then get the remaining part out once you pull the driveshaft. They should come out fairly easily though at that point, since they won't have any torque on them.BlackLX5.0 said:My bolts that holds the driveshaft to the rearend, the heads of mine are stripped, How can I get them off ?![]()
5.0 Nostalgia said:I use a way that someone on this website suggested. I soak the bolts with PB Blaster and let them sit for a little while. Next, I put the 12pt. end of a 12mm wrench on the bolt so that the opposite end of the wrench is facing the driver's rear tire. Using a floor jack, I jack up the end of the wrench. The driveshaft must be positioned so that when wrench is pushed up, it will turn and not just jack up the rear. Finally, rotate the driveshaft to get the next bolt in place. This has worked several times. I will admit my wrench is a little bent though.
