cant get in 3
Need more info....did you just miss a gear and are mad as heck now? I have a pro 5.0 and have missed gears occasionally, but its because I let off the clutch too fast.
What year is your car? Possably bent shift fork...or blew the syncro if it wont go in gear at ALL. :( If it goes in when the motor is OFF then its probably not the syncro, and I would lean to internal damage.
BTW turn off CAPS please. Makes it easier for us to read.
So it doesnt work for a while, then on your way home 3rd gear starts working? Is this only when your trying to shift fast?
I know if I miss 2nd at the track, it gets hard to go into 2nd for like a day or so...and just about every run after that I miss 2nd. Once it starts, its like my tranny screws for until it cools down. Is that what problem your having?
mustang023yes said:
ONLY WHEN I MAKE TWO PASS IF I GO SLOW SAME THING BUT WHEN I DIRVE HOME ITS OK I WAS GOING TO CHANGE THE CLUTCH
If it goes in fine any other time, in any other gear its probably not the clutch. Probably the syncros in the tranny. 1-4 syncros take a real beating in mustangs. 5th and reverse not so bad, since you dont go into those gears nearly as often, and rarely shifted hard into.
mustang023yes said:
yes thats is it how can i fix it caps off im new
Well as far as I know, the best way to stop this is to not miss a gear :D. Best thing for you to do, which helped my 1-2 issues a TON is to buy a steeda traix shifter's HANDLE, and change your transmission fluid to royalpurple. the last time to the track I made like 6 or 7 passes, and didnt even come CLOSE to missing any gears. It was great....do those two things and you should be fine :nice: .
