Cant get lower caliper bolt off...
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
I just cant get it off. I am pretty sure its stripped. I tried hammering a box end wrench on it, no luck, I tried hammering the T50 bit in it, nothing. And I can find my ****ing vice grips. :notnice:
Where can I get a lower caliper bolt with a normal ****ing head?
same thing happened to my honda about 3 weeks ago. i had my rotors turned close to 2 years ago and those idiots put the calipers back on with a air gun. which is fine if you know what you are doing. i found out ( 3 weeks ago ) they had obviously started it crossthreaded and just soured down on it instead of backing it out and doing it right.
it WOULD NOT come out. not only did i have to buy a new caliper bracket but a caliper and bolt as well :mad:
i wish i could say something to help. just make sure you work on it before 9:00. sucks when you find problems and need parts and the parts stores are closed :notnice:
Those are a nightmare. Are you by chance upgrading your brakes? If so you only need to take the caliper braket bolts out from the spindle. But otherwise, yeah, use lots of heat and elbow grease.
I had to use a BIG Pipe Wrench on mine.. The longer the better
Best part I went to sears to buy that torx bit for my socket .. It was a waste of time.. One turn I see that the bolt was getting stripped ..
Yea, mine is stripped as hell.
So does anyone know where I can get a caliper bolt with a normal head?
mine did the same thing when i did my brakes
i ended up going at it with a torch and a chisel/hammer combo....i finally got it to break loose after super heating it and hitting it with the chisel as hard as i possibly could.
good luck
I also ran into this. I held my breath, held the back of the breaker square into the hole and pushed on the breaker with the other hand. Click. Ya never know if it was a good click or a bad one till you try to turn it some more.
I neverseized the crap out of that bolt upon reinstallation. New bolts are 8 dollars at the parts stores here (reportedly - I only looked them up online so far).
Good luck.
