cant get the speedo out
  • Thread starter Thread starter 50foxbody
  • Start date Start date Oct 26, 2009
50foxbody
218
  • Oct 26, 2009
i cant get the speedo cable out of my cluster any one have any idea what it could be i dont wanna pry on it and screw anything up i tried squeezing and pulling and turning and pulling just wont come out (by the way its an 86 if it helps). i had no problem doing my 90 but this one is bein retarded. thanks in advance
lancec2c30
570
Washington
Oct 26, 2009
  • Oct 26, 2009
Where it attaches to the cluster there is that plastic clip. Under the collar of that white plastic clip. usually towards the bottom side there will be a little push pin retainer, you will only be able to see a tiny bit of it unless you pull back on that plastic piece. It's looks like a flat head screw almost, push it in and pull out on the cable.
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 26, 2009
  • Oct 26, 2009
Mine has the white clip that twist on and locks it in so it don't come out
50foxbody
218
  • Oct 26, 2009
well i tried twisting it that dont work ill try again tomorrow it got dark
lancec2c30
570
Washington
Oct 26, 2009
  • Oct 26, 2009
Huh, on both my cars. under the plastic clip there was a round metal push pin. you put a small screwdriver in it and wiggle it some, then the speedo cable slides out when the clip disengages. Takes all of about 20 seconds....
50foxbody
218
  • Oct 26, 2009
i know my 90 didnt have a push pin it just turned and slid right out
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
Z
Right side of cluster not illuminating 91 LX Hatch
  • Zeke1995
  • Jul 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2025
General karthief
