can't hit park!!!
jb1dsl
566
Marianna, Fl.
i have a 66 fastback a-code with the original c4. the tranny shifts like a dream still but it will not go in to park so im afraid to drive it anywhere because i do not trust the emergency brake. do you guys have any idea what the problem is. maybe it is a common problem with this tranny i do not know. i got under the car and i see nothing wrong.
please help!!
Have you adjusted the linkage? If not then do that first. Disconnect the rod from the shifter lever under the car. Then move the lever on the tranny into park without the shifter hooked up. Once the tranny is in park then loosen the adjuster nut at the shifter lever and make it fit with the tranny now in park. If any of the other detents on the shifter are out of whack now then it is time to replace all the bushings in the shifter to get it back to %100.
