- Apr 10, 2004
- 47
- 0
- 0
Well I have a 89, 2.3 L convertible that's kind of a project car for me and my dad...the only problem is we can't get it to psss inspection. We replaced the rotors, calipers and shoes on the front and the shoes, and springs on the back and got the drums cut. we took it to get inspected, and we failed because the back right brake wasnt working, there wasnt enough pressure so it was uneven. the other 3 were perfect. so we tried several things to fix it-we cleaned out the brake line, got new new proportioning valve and master cylinder-you name it we've done it. we took it to the local ford dealership and they said everything looks fine (they have no way to test the brakes tho) and to just keep replacing parts till soemthing works (lotta help they were for 70 bucks!
) our only hope at this point is to hope theres some air n the line that'll work its way outward after driving it awhile, and we'll ust have to keep bleeding i guess, but i'm pretty sure thats not the problem... what could be up?
There are only 3 inspection places in the entire state, and theyre spaced really far apart.
) so hopefully he wont have to go thru all this, all other states are more leniant, usually they just check to make sure all the parts are in the right place. but i explained the brake test earlier, and unless ur car is fairly new, it is difficult to pass. so they dont actually look at the brakes, they just get the computer readout and send you on your way...
