Can't stop it....
  • Thread starter Thread starter Sweeet Ride
  • Start date Start date Jul 5, 2007
Sweeet Ride
24
Calgary, Alberta
Jul 5, 2007
  • Jul 5, 2007
I recently switched out my 289 for a 408 and have been having trouble with brakes ever since. I have power discs on front and drums on rear as stock....they have always been very responsive and full brakes with the lightest touch 8until this engine change! front discs and calipers are next to new....2 year old master cylinder....
I think I have 2 separate problems (but maybe not)....
1...spongy pedal....not touchy and responsive like they were
2...even tho' the first pump of the brakes isn't great...the 2nd pump is almost non existant and the 3rd is not there at all....dangerous in city limits.
Seems like we're not makinfg enough vacuum off this engine....why would that be and how do I fix it?
iskwezm
4,159
20
79
Rowland Heights,California
Jul 5, 2007
  • Jul 5, 2007
Get a vacuum canister to store vacuum
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 5, 2007
  • Jul 5, 2007
Buy a vaccume gauge and check your setup at idle just to verify that this is your problem. I would be willing to bet it IS your problem but it is always a good idea to check stuff out before spending money.
Sweeet Ride
24
Calgary, Alberta
Jul 5, 2007
  • Jul 5, 2007
Where did you find that cannister in the picture you sent?
iskwezm
4,159
20
79
Jul 5, 2007
  • Jul 5, 2007
Summit or Jegs.Look for Vacuum resevior.
http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&Ntt=vacuum+resevior&searchinresults=false&N=+115
70vert
722
Bay Area, CA
Jul 5, 2007
  • Jul 5, 2007
Hydraboost or electric vacuum pump?
How about a Hydraboost (Hydroboost?) system if you have PS on the car? I may be talking out of the wrong orifice (sometimes when I sit down my voice sounds muffled, so maybe, lol) but are you guaranteed that the vacuum reservoir will always be full? I would hate to have any unpredictability in braking performance.
I was planning on putting in a Hydraboost or Electric Vacuum Pump Kit in when I put in my 408 - see here for the SSBC kit:
http://www.stainlesssteelbrakes.com/brakeproducts/brakeaccessories/Accessories
although I would want a quiet electric kit - not sure how loud the SSBC unit is.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 6, 2007
  • Jul 6, 2007
Hydroboost would be the better option if you have PS already.
I say trouble shoot the existing system to at least find whats wrong with it right now that way you can properly asses an upgrade or repair path. It could be as simple as a leaking vaccume hose or stuck check valve.
68RCodeConv
345
Houston, TX
Jul 6, 2007
  • Jul 6, 2007
The reason it is happening is because your current engine either has: (1) a massive vacuum leak, or (2) a much bigger cam than the previous engine.
You can fix (1) pretty easy. Fixing (2) requires replacing the cam with something with less overlap. Or get a vacuum reservoir. Or a vacuum pump specifically made for this purpose.
T
truck90278
382
Redondo Beach, CA
Jul 6, 2007
  • Jul 6, 2007
A vacuum reservoir will only hold the same amount of vacuum as the engine will produce. It does provide a source for vacuum which will help. As said in other posts, get a vacuum gauge and check the vacuum. You ideally would want to have 17 inche of HG to operate the booster adequately. Run the engine at 2500 and see what your getting. It does definitly sound like your low on vacuum. vacuum pump will solve the problem with low vacuum
Manual disc brakes
  • Butchd88
  • Feb 28, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
