CAR ALMOST DONE.
jetuomi
1,464
Toronto, ON
Well, my combo is almost ready, CAN'T WAIT !! One problem is, the 80mm Plastic MAF is so huge, I can't figure out a system to hook up the inlet tube to it and the t-body.. what have you guys done? use 4" pvc, 4" rubber connectors, and that's it? any thoughts? that, and my ignition are all that's left !!!
Dyno coming soon I hope !! (assuming it fires up !)
I do know what you mean about the maf. When I took mine out of the box I was shocked at the size.
For my home made CAI from the throttle body I used a 3 inch rubber plumbing connector to a 3 inch section of pvc pipe to another connector to the maf which is in the fender. The whole deal is a straight shot. Very easy and works good.
Later
Grady
This may help....My Pro77 is a 4" also....you can do up a PVC set-up....
4" to 3" Fernco for the MAF....then PVC to the TB.. a 3" will connect the PVC to the TB...
