  • 1994 - 1995 Specific Tech
car bogs at launch
  • Thread starter Thread starter eatsricejcd
  • Start date Start date Apr 6, 2010
E
eatsricejcd
76
  • Apr 6, 2010
The only way to launch this car is to do it slow and steady. If I'm on a hill its even worse.
I just got this car so I dont know how the trans and clutch is but the throw out bearing is gone and I know this has nothing to do with it. But considering the throw out bearing is gone I assume it still has the original trans and clutch.
The car drives perfect and doesnt drive lean or rich. Any suggestions on how to fix this and make it more responsive at the launch? thanks.
Tanus
847
A to the Z
Apr 6, 2010
  • Apr 6, 2010
gears?
IDK, with street tires its definatly a fine line between spinning them out of the hole or bogging, just keep practicing
ProKiller
3,064
15
78
PA
Apr 7, 2010
  • Apr 7, 2010
gears will liven it up a bit. have you done a tune up on the car? ditzy cap, plugs, wires, filters, etc.?
E
eatsricejcd
76
  • Apr 7, 2010
next mod is gears. the regular tune up things have been done. The car is no slug but I guess I'm just not used to the heavy sn95 cars and the low gearing.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Apr 7, 2010
  • Apr 7, 2010
Maybe you just need to feather the clutch at launch more. Don't engage it fully right away, let it slip a bit at first. You also might check your MAF, if it's dirty the car will not have much power. Search the forums for "clean MAF" and you should find instructions.
toyman
1,944
54
79
Vernon BC
Apr 7, 2010
  • Apr 7, 2010
Not yet mentioned but it's always worth while to check for any stored fault codes in the PCM. The check engine light doesn't need go on for a fault code to be present. Diagnostic port is in th engine bay passenger side between the strut tower and fire wall. It will require an OBD-1 reader. Unless it's a V-6 the port under the dash is non-functional so don't let a shop tell you that they can't connect to the port.
E
eatsricejcd
76
  • Apr 8, 2010
update...
cleaned maf wires and dist cap with sand paper. drives night and day different . Next on the list is a CAI and 3.73 install. Might hit the track before I do it to see what the difference in the 1/8
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
