Car cutting out after 2000rpms
03GTMO
I have a 95 GT, we just put ported GT-40 heads, F-cam, U/L intake manifold, throttel body, CAI, MSD 6AL ignition box, Blaster 3 coil, holley 255 pump, Aeromotive adjustable fuel pressure reg., cap, rotor, and autolite 764 gapped to 42.
Car will start and idle fine, but when it is under a load ie driving, it starts to cut out at 2000 and will barly make it to 3000
Thanks in advance, any advice welcomed
Have you pulled codes?
I'd check for spark leak - it can rear its head right where you're at. Also, if you haven't, bypass the box and see if the issue abates.
Good luck.
