car didn't start?? help please...(pics)
mustangsally93
281
Omaha,NE
My car went to this
to this in 24 hours
Well we got it all back in and stuff. When we started to do the timing, it just would'nt stay running. So we moved the dis. around a lot. We had it running at 500 rpm but it was running bad. It would run fine at 2 or 3 grand. No leaks or knocking or anything. We have every thing right I think. Could it be a vac. leak?( we didn't think so) I'm just lost.. if you guys can help thanks, or if you need any other question to help just say it..
lmarinukjr said:
check timing and firing order mine did almost the same thing i had firing order on 2 cylinders wrong
IF THE TIMING WAS OFF WOULDN'T IT BE BACK FIRING? ALSO WE GOT THE PLUG RIGHT AFTER THE SECOND TRY, ALSO HOW WOULD A VACUUM LEAK MAKE IT NOT RUN AT ALL? also on the bottom of the upper intake I'm sure we missed the lines up under there.
ok guys........ It only did that a little for a spot about a inch on the dis. We moved it every which way and didn't run at all if you let off the gas. It should run ( bad or good) and one point. But no matter what it didnt. I put the cam and crank shaft marks straight up and down on the timing chain. I dont know what else to do? Also do you guys have pics or anything to know where the vaccum lines go? my book didnt show to the point where they go.......and when I get this done I'm saleing all of my pony! I tired of miss with this sh it!
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
