It's been pretty cold here lately, so I let the car warm up for 10 minutes or so (does great things for gas mileage
) when it's cold. The last couple days I can start the car and it'll start at about 1500 rpms (has to do with the clutch safety switch, didn't do it until I hooked that up) and then the rpms will fall to 500 and the car will die unless I give it gas. It'll do it a couple more times until it gets warm enough or something - I usually hold it about 2500 or so for 30 seconds-ish just to make sure. It usually idles around 750-800 (by the stock tach). What could be causing this? I'm sure it's cold-related, doesn't do it otherwise.
Ash
) when it's cold. The last couple days I can start the car and it'll start at about 1500 rpms (has to do with the clutch safety switch, didn't do it until I hooked that up) and then the rpms will fall to 500 and the car will die unless I give it gas. It'll do it a couple more times until it gets warm enough or something - I usually hold it about 2500 or so for 30 seconds-ish just to make sure. It usually idles around 750-800 (by the stock tach). What could be causing this? I'm sure it's cold-related, doesn't do it otherwise. Ash
