  • SN95 4.6L Mustang Tech
Car dies when put in park?
  • Thread starter Thread starter paintballpyro1
  • Start date Start date Jun 3, 2009
paintballpyro1
118
Michigan
Jun 3, 2009
  • Jun 3, 2009
Recently my 96 gt has started stalling when i put it in park. Ive noticed it does it for a little(maybe a week) then goes away but then comes back after a few months. Its not so much when the car is cold but when its warmed and i get home and park the second i drop it to park it shuts right off and displays the dash lights like your just about to start it again. Also i noticed that the battery(couple months old) gauge drops to almost nothing when it gets put into park. Any ideas why?
Twista
510
@ the z00 in chicago
Jun 3, 2009
  • Jun 3, 2009
maybe//// Ford Mustang IAC IAB - Solving your idle problems
paintballpyro1
118
Michigan
Jun 4, 2009
  • Jun 4, 2009
Hmm wouldnt hurt to try it, thanks. Like i said its weird, only does it for a week then goes back to normal for 6-7months.
Miles
1,225
Burlington, ON
Jun 4, 2009
  • Jun 4, 2009
Will the car idle well in drive? Could be a vacuum leak which are more prominent at idle but odd that your symptoms dissapear and re-appear. Electrical?
paintballpyro1
118
Michigan
Jun 4, 2009
  • Jun 4, 2009
Yea idles just fine, no surges or anything at all. Like i said i noticed that my battery gauge drops down to almost nothing right when i put it in park like i lose all power. As odd as it sounds when i leave my ipod connected and park my car it stalls but like last night i disconnected it before i parked and it didnt stall on me. I have no clue whats going on, since i got work today im gonna try disconnecting my ipod before i put it in park and see if it still stalls or not but that would be weird if it was the ipod some how haha.
281CI96Coupe
233
  • Jun 4, 2009
Me and friend both had the same problem you had. The thing is that when you disconnect the battery, you reset the ecu so that it is forced to learn how to do everything again such as idle, idle in drive, neutral etc etc. The trick is to drive the car when its stone cold so the car doesn't stall on you, and after 20mins of driving it should be fine, other than that if you have a really weak battery it would just make matters worse.
paintballpyro1
118
Michigan
Jun 4, 2009
  • Jun 4, 2009
Havent disconnected the battery in awhile, battery was replaced couple months ago so it should be fine. Im gonna get both alternator and battery tested tmw for the hell of it while im out.
A
agentl074
  • Jun 5, 2009
Maybe it needs reflashed Have you done any tuning with it? Is it throwing any codes?
paintballpyro1
118
Michigan
Jun 5, 2009
  • Jun 5, 2009
No codes or anything. Ive used sniper tuning software but my car did it before i used it. Someone mentioned the TR senor(fords netural safety switch) while i was up at the store. Would that cause anything. Its not harming anything just annoying but kinda wanted to figure whats causing it.
A
agentl074
#10
  • Jun 6, 2009
  • #10
Does it go away when you step on the clutch?
four six
506
Hobart, IN
Jun 6, 2009
#11
  • Jun 6, 2009
  • #11
5 speeds have park?
A
agentl074
#12
  • Jun 6, 2009
  • #12
5 speeds have park?
Yup, its right there by your right hand.... You just pull upwards and it puts it in park... that's why they call it a parking break
paintballpyro1
118
Michigan
Jun 6, 2009
#13
  • Jun 6, 2009
  • #13
yea was gonna say its an auto...
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 8, 2026
DadLife0724
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
