  • 1994 - 1995 Specific Tech
Car doesn't start....sometimes
  • Thread starter Thread starter ef200098
  • Start date Start date Sep 9, 2005
E
ef200098
123
  • Sep 9, 2005
My car will start right up sometimes and other times it will not. When it will not it will click once and power there will be no power...can't lock doors or open windows. and if i wait a little while and try it again it might or might not start. i went to autozone and they said that the battery and alternator is good. Anyone have any ideas?
Mike
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 9, 2005
  • Sep 9, 2005
sounds like a bad/low battery
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Sep 9, 2005
  • Sep 9, 2005
I had al little issue the other day, where my ccrm wouldn't cut off. wiggled the negative trminal on the battery, cut off. You case sounds like a bad ground somewhere, might be the neg. batt. terminal. No power at all negates this, but a while ago my would start intermittently, found the nut the holds the ground to the starter totally gone.
good luck
HISSIN50
34
129
Sep 9, 2005
  • Sep 9, 2005
Yep- a bad ground connection can do this.
GRGT1994
1,034
  • Sep 10, 2005
Clean the battery terminals? Are you sure the battery is good?
E
ef200098
123
  • Sep 18, 2005
i bought a new battery and my car started fine for about 10 days or so. no problems, now it is doing the same thing.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 18, 2005
  • Sep 18, 2005
remove, clean and reinstall all ground connections. There are 3 at the battery, 1 on the right side of the timing cover and one at the front of the oil pan bolts.
Scott
E
ef200098
123
  • Sep 18, 2005
Are you sure its a ground? could it be the starter. i try to start the car i get one click then all power in the car is gone for about 10 seconds then it comes back on. battery voltage is still at 12.85. then when power comes back on i try to start it i get one click, loose all power then comes back in like 10-15 seconds or so.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 18, 2005
  • Sep 18, 2005
Mine currently does the same thing, but in my case it's a ground issue. Somewhere in my ground wire, there's resistance, and it's worse after the engine is warm, since heat amplifies the problem. I replaced the terminals on the cable, and it helped for a little while, but does it again, so when my engine comes out, I'm replacing the cable entirely. I'm voting for a bad connection somewhere.
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
J
Car won’t start
  • JLB
  • Nov 15, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
