CAR GETTING HOT!!! PLEASE HELP
aod92
104
My car is gettin one to two notches away from the red mark on the stock gauge. I've been having these problems ever since i went to an electric fan from a taurus . And i changed my water pump from reverse flow to standard flow. The reason i changed water pump direction is because i removed the power steering a/c and smog pump. And now i have to run my belt on the top of the pulley instead of on the bottem. Someone told me that i also should have changed the timing cover to standard flow also because now the water is flowing thru the cover the wrong way. But i don't think that would make it run hot. Any help from someone that is also running a standard flow water pump would be greatly appreciated. Thanks.
