I recently put a new engine in my car. After the install I performed all the correct break-in procedures. I've found that whenever in first gear and you nail it, it cuts out and seems to have no power. After you shift into second it still wants to cut out a little and then clears up after mid second gear the rest of the gears seem fine, but if your just cruisin at the same RPM it cuts out a little every now and then. It revs fine when its in neutral and there are no signs of cutting out or anything, anybody have any ideas?
Another problem I have is that when you go past 55 mph the car and shifter start shaking real bad. If under full acceleration it doesn't do it very badly until you let off the gas and just start coasting, then the shifter starts shaking like a SOB.
Any help is greatly appreciated!
Thanx
Casey
Thanx
Casey
is it a stock pump(it doesnt say in your sig)? i would also check timing and your codes. vibration could also be fuel or ignition related, im doubting the driveshaft being the culprit since you never said it did it before the new motor. good luck with the gremlin
