Car idles too fast
My 93 lx 4 to swap is all completed. It idles too fast though. The throttle body is closed and it still idles about maybe at 900 rpms. I changed the IAC and it's still fast. There's a 3/16" hole in the throttle body plate. Does that hole belong there? \
What would make it idle so fast?
There should be an adjustment screw on yout TB,but after you adjust it you have to re=adjust your yourrrrr,,,,what the hell is it,,,,the black plastic thing on top of the TB.Make sure it reads 95 or better!! What type of MAF do you have? If its a pro M you mite want to try rotating it and see if affects the idle!!
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems. The first post in the sticky has almost all the details you need.
