car in ??limp mode??
i have a 89 mustang 5.0 converted to mas air. my car feels like its in "limp" mode. its slower then ever absolutely has no power. but it sounds like a v8 lol. well for awhile now my temperature gauge hasnt been working so i was hoping once i fixed that, that the car would act a little better since the temperature is sent to the computer. im pretty sure i have all the sensors hooked up. i could be wrong but i dont know what more i need. any help would be appreciated. my car has e cam, gt40 heads, explorer lower and upper intake.
89 model Mustangs were all Mass Air from the factory.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
