car is possesed
ive been having a prob. w/ car and ive just about given up. In the morning when i first start it i need to keep foot on gas or else it dies. Once i start driving the idle is fine at 800. after 10 min of being fine it goes to die at red lights and when i come to stops. ive changed aic 3 times within 1 month. cleaned out tb, set tps. what could be causing this. the car also backfires on downshifting, dont know if that has anything to do with it. It follows this same exact pattern even when i shut it off and start it back while its still warmed up a few min. later.(comp?) Any help would be great.
thanks
as i recall, you can use a test light as well (in lieu of using the CEL)................. just in case. good luck.
