Car loses power and backfires when you hit the gas
  • Thread starter Thread starter Green93LX
  • Start date Start date Jul 12, 2007
Green93LX
96
Mobile, Al
Jul 12, 2007
  • Jul 12, 2007
This isnt about a mustang its a '97 Mountaineer. Its had this problem for a while now but it seems to be getting worse. Everytime I hit the gas the car just has no power for about 2 seconds, then all of the power comes back just like normal. No matter when I hit the gas it always has this hesitation and half the time it backfires then. Can someone please tell me what could cause this and set me in the right direction?
K
kygt
  • Jul 13, 2007
Start with checking for codes , then check MAF for leaks, defects or contamination . Verifie proper fuel pressure while making it back fire and under load , also check for vacuum leaks . A backfire through the intake is a sign of a lean condition ( low fuel pressure or too much unmettered air ) so I would start checking these things frist , Of course a timing concern can cause it but not likely that it would run ok after the breif pop or hesitation.
john
conartist
77
Windsor, Ontario, Canada
Jul 13, 2007
  • Jul 13, 2007
Fuel Pump Pressure or Timing, IMO
Green93LX
96
Mobile, Al
Jul 13, 2007
  • Jul 13, 2007
thanks for your replys... After fooling with several different things for a few hours I gave up and called a friend of mine. We only got through 1 beer before he guessed that the Camshaft Position Sensor was out. We disconnected the harness from it and now it runs perfect. I'm going to the junkyard tomorrow to see if I can find one in descent shape to put on thier.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2026
Mhaley2006
M
