  • SN95 4.6L Mustang Tech
Car Running Hot
  • Thread starter Thread starter Edis417
  • Start date Start date Jul 24, 2004
E
Edis417
Los Angeles
Jul 24, 2004
  • Jul 24, 2004
I have a stock 96 GT with an automatic transmission and almost 100,000 miles on the odometer. The cars runs fine, however it's been slowly running hotter and hotter over the past few months and has now gotten to the point where I'm starting to worry about overheating and damaging my engine. I started noticing this increase in operating temperature when I switched to 4.10 gears if that makes any sense (it might just be coincidence). Anyways, I've flushed the radiator and changed the coolant, but the car is still running too hot.
Any ideas or suggestions?
1tirefire
118
Northern Bay FF/SS
Jul 24, 2004
  • Jul 24, 2004
ever change the t-stat? Take it to the mechanic. I know my fan used to come on at just over 200 degrees with my 98 auto.
mransr
1,188
36
98
Riverside, SoCal
Jul 24, 2004
  • Jul 24, 2004
same prob here...(2000 with 100k miles)...
I changed out the T-stat, radiator cap and had a flush/fill done without any effect...
mransr
1,188
36
98
Riverside, SoCal
Jul 25, 2004
  • Jul 25, 2004
bumpage...
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Jul 25, 2004
  • Jul 25, 2004
If you don't have one yet, get a transmission cooler as Engine damage isnt the only thing you have to worry about, especially on an automatic car as heat is the number 1 killer of the automatic. The 4.10 gears with their increased rpms are also only increasing the problem so I can see how that would cause the engine temp. to go up somewhat. As the other guys have said, it could be your thermostat is going bad. I'de replace it with a 180* thermostat and then flush the cooling system if that hasn't already been done. Although if you get a cooler thermostat you'll need to get the ECU flashed for it to work properly.
R
Roger_4.6_96
1,209
Reno,NV
Jul 26, 2004
  • Jul 26, 2004
1996 Mustangs GT and Cobra have problem overheating. mine runs all the way on the L of Normal
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
R
Engine Fox body doesn’t run hot until I start driving
  • Rose5oh
  • Mar 17, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
limp
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
D
Engine how fast would an engine overheat with zero coolant
  • dqureshi06
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 8, 2024
Mustang5L5
