  • 1994 - 1995 Specific Tech
car running rich....
  • Thread starter Thread starter Mustangless
  • Start date Start date Apr 13, 2006
Mustangless
903
home
Apr 13, 2006
  • Apr 13, 2006
My mpg in city have been bad for a while 12-14 going easy on it. My hwy mpg is alot better though, 23-26 mpg going easy.
Today I started my car with the door open and I could smell gas fumes. I also was told a while back that my car smoked black when I was at the track. My exhaust insides are black too.
I have cleaned my maf sensor, my ect runs at 204 (if that has anything to do with t-stat).
What else could I should I look for?
J
jsedlar
  • Apr 13, 2006
I am having a problem running a bit rich... More rich now then the past 2 years i have been driving it.
HISSIN50
34
129
Apr 13, 2006
  • Apr 13, 2006
What do you mean about the ECT? It's a thermistor that will have varying voltage/resistance readings depending upon the temperature it sees. Do you mean that the low speed fan comes on at 204*, indicating calibration at that temp range at least?
HISSIN50
34
129
Apr 13, 2006
  • Apr 13, 2006
Oh, I just saw your TwEECer. Any idea about your stoichiometry at idle?
Good luck.
Mustangless
903
home
Apr 13, 2006
  • Apr 13, 2006
Good luck.
I am still new at the tweecer. What is the stoichiometry?
I did some datalogs today and will try to post them tommorow. I did notice when I was logging when parked it said my throttle was part and I was not touching the gas pedal and my rpms were kind of high.
I will try to get some logs posted tommorow.
HISSIN50
34
129
Apr 14, 2006
  • Apr 14, 2006
Stoichiometry is air/fuel ratio.
Your logic is sound - if the puter is loading at idle because it thinks you have the gas pedal pressed a little, that could lead to wasted gas while idling. Note that when it gets to things like that (where the puter baselining the TPS comes into play, along with real-time dynamics) Grady, Don and all the other smarties are the ones to ask - not me.
Good luck and bump.
Mustangless
903
home
Apr 14, 2006
  • Apr 14, 2006
http://rapidshare.de/files/18001795/datalogs.rar.html
there are 4 datalogs. The one named idle is the one that I am wondering about. I think the tps is .970 there
I dont have a wideband, thought about getting the lc-1 but installation looks confusing.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
