Car Runs Really Hot
influence
46
I have a 91 5.0 it runs really hot
PWR Aluminum Radiator
Electric Fan
Upgraded Alternator
180 deegree thermostat
It usually runs at...welll Im assuming 235-245 degrees its ridiculous...it used to spew coolant till I figured the perfect radiator and overflow levels....but it still runs hot.
The fan is thermo activated once it hits 160 degrees.
This ticks me off...besides the numerous other issues I have
Thanks in Advance
Both at idle it will get to about 200 degrees, that is sitting for a bit though, but when I drive it gets hotter.
I also just changed the plugs, did a radiator flush and engine flush, changed the oil and a new thermostat(180).
There is no smoking of the motor, the oil is clean, and no coolant oil mix on dipstick or or in radiator.
It is the stock temp quage with a brand new sending unit.
The Fan actually works great I have it set to come on at about 160, it stays on the entire time , long after I shut off the car. I do not have any aftermarket pulleys on the car. I will look into the cobra pulley, though thanks
You need another means of checking temperature than the stock gauge. Otherwise, you have no idea where you're at.
If you are indeed at 200*F while idling and higher thereafter, something is systemically wrong or you have multiple issues. Be sure the t-stat is opening fully, and doing so when it should.
Is there anyway you can clue me in on a few things to start checking?
The thermostat is new and Housing
The Water Pump is new
The Radiator is New
The Fan is new
The Serpentine Belt is New
The Motor has 60k on it
I would love to start narrowing this down because it is irritating.
Thanks
The Radiator is New
The Fan is new
Thanks
New t-stat doesnt = good t-stat. Be sure it opens fully by 190*F or so.
Be sure the system is bled properly.
Be sure the air dam under the car is present.
Be sure your fan is spinning the correct direction. It should pull air towards the engine (away from the radiator).
And again, you NEED to have a real gauge. The stocker is not accurate, nor accurate enough for diagnostics. A mech gauge from the parts store is about 20 bucks.
Good luck.
what fan do you have exactly? I remeber on my dads cobra, he had the same problem as you, it turned out the electric fan was not strong enough to cool. Also, be sure your not wired wrong and blowing the air outward. Funny as this sounds, it happens, make sure it is pulling air from the outside into the engine compartment.
I would not worry about the fan right now. It runs hot at idle and gets hotter once at speed (where the fan doesnt even matter).
your correct and incorrect yes it WILL run if it needs to! and IF the fan cannot support what the car needs for cooling then that will be a problem. My father has a speed shop and you wont believe how many people change from a clutch fan to a electric fan and put the wrong size on... or better yet the fan just does its job and something silly as a air dam removed, bags, or just one really hot day- will have you chasing your tail! So the fact that he doesn't know the cfm size could be the reason this all started but now its not the problem!
but you still need to go thru the steps to figure out A) the problem and B) what caused it!
check the basic:
1) do you have a leake or Bad head gaskets! You can buy a cheep pressure tester!
2) do you have a worn belt tensioner, or a bad belt..... YES the water pump pulley will slip!
3) is my water pump bad?
4) can my fan pull enough air?
5) did i remove the air dam or is something causing a blockage?
6)is the radiator anygood?
Sounds like you killed the head gaskets and it pressurizing the cooling system...
check the basic:
+1. You need to check on that fan asap. The fan my dad was using was a flexlite. Like i said also be sure it is blowing the right direction
If I did blow the head gaskets wouldnt there be some sort of oil/coolant mixture in the radiator or coolant resevoir or on the dipstick/ oil cap?
I think the fan is 2450 CFM
It is a fairly new PWR Radiator with approx 1000 miles on it.
I just replaced the belt should I try to get a hair smaller belt to make it tighter?
not all the time buddy. I had a bad head gasket and none of those symptoms. The way i knew it was blown was becuase my coolant sysytem was being pressurized, causing the coolant to spew out of the overflow. You can check to see if there is coolant in your oil by changing the oil. Since the oil will obviously sit on top of the coolant, you will want to look real closely right after you pull the drain plug. The coolant will be the first thing to come out. I doubt that u will find any on the dipstick since it sits on the bottom.
check the basic:
How am I incorrect? He has an issue or cannot reject enough heat, even while ambient air flow is sufficient. People are focusing on his fan, when any fan he uses will not fix the heat-rejection issue. If the fan was the issue, he would cool nicely at speed but heat up while stationary.
