Car Runs Really Hot
  • Thread starter Thread starter influence
  • Start date Start date Oct 9, 2008
First Prev 2 of 2
D
daschae
#21
  • Oct 10, 2008
  • #21
I have a 1990 5.0 40k on motor, underdrive pulleys, k&n, full bbk exhaust, 3 core aluminum radiator with dual high cfm electric fans. I am having the SAME EXACT PROBLEM! I just picked up a compression tester and as soon as my car cools down I am going to check the compression. The only other thing I have found may be an issue is that I dont have an Expansion Tank, aka coolant overflow tank. I think maybe I should have got an F-body camaro ;>)
Dino Dino Bambino
1,673
90
79
Cyprus
Oct 11, 2008
#22
  • Oct 11, 2008
  • #22
Nobody has mentioned the possibility of a bad radiator cap. If it doesn't hold pressure, the overflow bottle will fill up while the coolant in the radiator goes down. The coolant will gradually boil away and the engine will run hot. The telltale sign of a bad radiator cap is bubbling inside the overflow bottle as soon as you turn the engine off.
L
LxVert
80
#23
  • Oct 11, 2008
  • #23
D
daschae
#24
  • Oct 11, 2008
  • #24
Checked the cylinders, all of them are between 120-130. Took the thermostat out and just ran the car 50 miles, never left the bottom of "Normal" stayed right around the L. I just put that thermostat in! Since I live in So Cal, Im thinking of just not running a thermostat.
M
mike0227
53
Houston Texas
Oct 11, 2008
#25
  • Oct 11, 2008
  • #25
Not a fan problem
As previously indicated fan is not necessary a highway speed and your car runs hot on highway. It must be another problem such as missing air dam, restricted air or water.
ShortThrow50
923
Pa
Oct 11, 2008
#26
  • Oct 11, 2008
  • #26
Prolly a bad thermostat then dude
First Prev 2 of 2
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Engine Help diagnose random overheating??
  • TomOsiris
  • Apr 10, 2022
  • 5 6 7
17K
Fox 5.0 Mustang Tech Jul 3, 2023
General karthief
My saga of keeping the car running cool
  • hoopty5.0
  • May 19, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2022
hoopty5.0
