  • SN95 4.6L Mustang Tech
car sat for a while, now it haz miss
  • Thread starter Thread starter aar0s
  • Start date Start date Apr 15, 2012
aar0s
1,015
55
69
Apr 15, 2012
  • Apr 15, 2012
Ok, took the 01 in to get painted in January, it had less than a 1/4 maybe an 1/8 or less in the tank when we dropped it off. Picked it up a couple of days ago and went right to the gas station and put 20 bucks in it and she was running fine. Pulled it out today to clean the water spots off it and before it got out of the drive it had a miss. I figured it was just bad gas working its way out but just in case I put some fuel injector cleaner in it, drove it about 15 or so miles and it still has the miss. Could it have a fouled plug misfiring and not be throwing a code?
Z
z28forlife
  • Apr 16, 2012
Definitely a possibility. 4 months just sitting, gas starts going bad after about a month.
Three50won
1,135
64
69
Apr 20, 2012
  • Apr 20, 2012
It took them 3 months to do a paint job? Any reason why? And after THAT much time, are you sure they didn't screw around with your car? I'd say pull the plugs and inspect them...maybe even replace them.
aar0s
1,015
55
69
Apr 20, 2012
  • Apr 20, 2012
It took three months cause the guy worked it with when he had time between other jobs, way things worked out its a good thing he did. I was not in a hurry to get it back, I don't drive it in the winter anyway.
Three50won
1,135
64
69
Apr 20, 2012
  • Apr 20, 2012
Oh ok...well I'd say start with the plugs and check the wires while you're at it. It's weird how you can have your car running perfectly and then it sits for a while and has a million problems when you start it up again. And sometimes your car can have a million problems but then when you let it sit for a while all the problems just magically vanish. Sheesh...good luck with it.
Maxpowers
859
Pittsburgh, Pa
Apr 21, 2012
  • Apr 21, 2012
A bottle of stabil is cheap. No reason not to use it over the winter.
fiveohwblow
Official Member
2,169
145
155
Apr 21, 2012
  • Apr 21, 2012
Moving bad gas through a filter will do damage when it's 11 years old. Change it first, and get good gas in there.
aar0s
1,015
55
69
Apr 21, 2012
  • Apr 21, 2012
Filter and pump were changed last summer, but I guess a new one wouldn't hurt.
Maxpowers
859
Pittsburgh, Pa
Apr 22, 2012
  • Apr 22, 2012
Pull the plugs and check them. Inspect the COP's for possible damage.
aar0s
1,015
55
69
May 5, 2012
#10
  • May 5, 2012
  • #10
Follow up on this, car gave me a cylinder 4 missfire code yesterday, change the # 4 plug and still runs like chit. Moved the #4 COP to #5 plug then it gave me a #5 misfire, problem followed the COP, new part and she's running fine.
Thanks for all the suggestions with this!
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
