I just started having this problem but from 2-3000 RPM at wide open throttle my car will sputter and backfire and buck like crazy but as soon as 3000 hits it takes off like a rocket? If i go at anything lower than wot through the rpm range everything is fine. I ran the codes from my comp and i get code 41 and 91 and unless i bump up my fp to around 50 w/out vacuum the code stays there, and if i put vacuum on the car it will give me the lean code no matter what. My fp drops about 5 psi if i put the throttle down with the vacuum on the regulator, is this normal, i thought the fp was supposed to stay the same no matter what the throttle position is? With no vacuum the fp stays constant and the misfiring seems a little better than with vacuum. The car has gt-40p heads, trickflow intake, 24lb injectors and a c&l 76 mass air meter. Could it possibly be a coil issue or TFI module? I already put in a new pair of plugs and it didn't help. The plugs also look good after a run. Any ideas???
Thanks,
Tyler
Thanks,
Tyler
