Hi everybody I have a 1989 Mustang GT 5.0 t5 manual transmission. My mods are K&N air filter with Factory air box C&L 76 mass air meter professional products throttle body 65 Holley systemax upper and lower intake manifold 24 injectors 1.7 rocker arms ported stock cylinder heads BBK shorty headers with the stock H pipe Dynomax super turbo mufflers Cat-Back exhaust.. had this for quite awhile... like the title says when I come to a stop with the AC only on it wants to die sometimes it dies and sometimes it doesn't but when I don't have the AC on no problem at all...the things I've done new idle control valve new spark plugs and wires I've checked the freon in the AC system it's a 40 PSI I've clean the mass air meter done the basic idle reset put the TPS sensor to .97 put a new VSS sensor fuel pressure is at 42 with a stock fuel pressure regulator I even tried putting the idle higher to 900 it works for a little bit and then within 3 days the problem comes back I even cleaned all the grounds check the vacuum leaks everything looks pretty good can you guys help me out thanks in advance
