Engine Car stalls when going to a stop with the AC on
Agreed. Usually when you roll to a stop the VSS signals the ECU and the iac will open up s tad.
So either the signal isn't reaching the ECU or the iac isn't responding as it should .
However, doing it once engine warms up also is a hint it might be sensor related as well.
I'll look at the VSS and the idle control valve again but I already got a new VSS also and the idle control valve is new
I'll try to look at the wiring of the VSS and the idle control valve Maybe something's going on there by any chance would 24 injectors have to do anything with this bad idling maybe it's too much gas?
Is there any way to test the volts for the VSS how many volts should it be at??
The VSS does not use voltage for measuring vehicle speed. Voltage output could vary from car to car and with wear and resistance of the connections and wiring.
The computer uses frequency output: as the car speeds up, the VSS output frequency increases. The computer takes the frequency output value it received from the VSS sensor and converts it into MPH. The only way the frequency changes is to make the driveshaft turn faster. Under normal circumstances, that means the car is traveling faster.
In fox body Mustangs a defective VSS will usually set computer trouble code 27 or 28,
Is that bad? I have 80 amps at idle... I don't have a sound system just AC headlights and fog lights.. nothing extra
Bad? Is the car going up in flames bad? You have an unaccounted draw of 20A.
Something is seriously wrong. How are you measuring this? DC clamp meter?
I've measured current when Mark VIII fan (using relays) is running with engine on...about 100A. With no eFan, it's about 60A.
GT fog lights are a separate but related issue. You need to get them off the headlamp circuit. I suspect you're headlamp switch is burned & melted. This could be where the excessive current is going. Could also be a bad 3G alternator, if diodes are shorted & not blown. Is the 3G fused?
Reactions: michaelgt
I don't have any codes maybe I'll just check the wiring for the VSS maybe something there is wrong
https://lmr.com/item/SVE-9902A/Mustang-4-Gauge-Power-Wire-Kit-Premium-W-Noise-Suppression-3 that's what I got with my 3-g 130amps alternator. and no my car is not going on fire it runs great just with the AC on it wants to die. and usually it does so right now I'm not using my AC
And as for the fog lights I already "upgraded" with the relay so my fog lights and headlights are too different circuit maybe I have a bad alternator?
I measured it with the O'Reilly tool it said that it has 80 amps at idle
I believe that when you turn a/c on the idle is suppose to kick up some.there is a electric connection on the compressor ,check that out and you might just solve this mystery?
There is an idle up to compensate for the load. The ECC gets a signal that the AC is on and initiates slight idle up.
Electrical Load shouldn't change much, just the engagement of the clutch.
Give me a day or so and I can take a load reading at idle with ac on and off. Currently downpouring
