trick flow top end kit and now that it's 100 in MD it's starting to over heat.During trick flow install i had the water pump replaced and a 180 Mr Gasket thermostat installed.The top radiator hose gets hot but is very soft,the oil looks clean so i don't think it's a H/G.I thought I might have air in the system so I jacked up the front end and let it idle with the cap off for about 10 minutes.After 10 min it started gushing water out of the opening.I do not have an over flow bottle but never had a problem with it running hot before.I only have the stock guage but it climbed to nearly 250 just idling when i was trying to burp it.Any advice would be helpful and I hope I didn't F anything up by letting it get so hot.
