car still won't idle
U2SLO450
118
i have an 87 t-top gt with all the bolt ons and recently it began stall at stop signs and now it wont even stay running if you dont feather the gas pedal, when you take off you can hear it popping under the hood (in the intake i guess) then it takes off and runs like it should but as soon as you slow to a stop it dies, I've already replaced the plugs, wires, rotor, coil, fuel filter, checked timing, IAC, mass air sensor, new throttle body and probably more things that i cant think of right now. Anyone have any new suggestions? Any input is appreciated.
When the computers go south, there tends to often be massive system faults.
Yanking codes is always key - especially since you shouldn't have a functional CEL.
For a real quick test, grab your dizzy and see if it's bolted down tight. Or toss a timing light on and make sure the timing didnt self-retard from a loose hold-down.
Good luck.
