i have a 1993 mustang gt convertible with a manual transmission, and for the last few weeks the car has been hard to put into gear, but last night i was driving and all of the sudden the clutch pedal felt like there was no weight or tension on it, and i couldnt change gear, unless i put about all 200lbs of weight into the shifter(not smart but i was less than a mile from home). Its an automatic adjusting clutch(pull back on the pedal and push it in 1st gear) and everything is stock, and i replaced the throughout bearing in March, and everything has been perfect until i have been driving back and forth from college and i began to notice the transmission began to get harder to shift. when i push in the clutch pedal and try to put the car into gear, it acts like the transmission is blocking the shifter and the engine acts like the clutch is still engaged because the RPM's drop and the engine begins to bog. i think its the linkage between the clutch and the pedal because i cant put the car into gear, but what is your take on the situation, i would appreciate any help i could get.
