Car Will Not Idle!!!!!!!!!1
  • Thread starter Thread starter 89gt40lx
  • Start date Start date Sep 19, 2005
89gt40lx
Orlando Florida
Sep 19, 2005
  • Sep 19, 2005
I HAVE A STOCK INTAKE NOW... with gt-40 alluminum "Y" heads, E-CAM 24lb injetors 70mm mass air....
CAR WILL NOT IDLE!!!!!!
will idle for about a minute then it shuts off...then when i go to fire the car back up it just cranks for almost a full 60 seconds and i have to feather the throttle to get it to fire back up.. then one big puff of black smoke (gas) the most potent gas smell ever....
its like car car is getting too much fuel...(flooding) but its fuel injected im so confused
D
Daggar
3,902
  • Sep 19, 2005
Please provide a brief chronology of the parts you've recently installed including:
heads
cam
intake
fuel injectors
throttle body
mass air sensor
... anything that you've done or installed new since the last time your car ran.
Black 93 Fox
1,995
Vancouver,Washington
Sep 19, 2005
  • Sep 19, 2005
Like Dagger sad more info would be helpfull. Have you tried reseting your idle by doing the TPS, and idle set screw?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 19, 2005
  • Sep 19, 2005
See the Sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems.
89gt40lx
Orlando Florida
Sep 20, 2005
  • Sep 20, 2005
i have gt-40 aluminum heads, E-cam, 24lb injectors 70mm mass air x-pipe, mac shorties and mufflers
D
Daggar
3,902
  • Sep 20, 2005
Ok, that's the second time you've told us what you've "got". Tell us what your car already had installed the last time that it ran correctly. Then tell us specifically, what those parts are that you most recently installed that are now making your car NOT run correctly. In other words: What exactly are the changes you made between the time that the car ran well and now. Saying only that you've got parts X, Y, and Z, doesn't tell us squat. The parts themselves are not the problem (unless they're broken). How do you exepect us to help diagnose the problem with nothing more than a list of parts? What exactly was taken apart? What parts were reinstalled and what parts were replaced since the last time the car ran well? For all I know, you're trying to run a 70mm MAF sensor on an SD computer or maybe a 70mm sensor calibrated for 19lb injectors with 24 lbers. You get my meaning?
89gt40lx
Orlando Florida
Sep 20, 2005
  • Sep 20, 2005
i bought the car it was stock...it ran fine..........ok..........i put the heads, cam, injectors, rockers on the car it ran fine....then i put on an msd 6AL i cant remember if the car started the problem befor or after the msd..but when i put on the heads cam injectors mass air it ran fine for about a week...also when i put on the heads and stuff i put a new stock fuel pump in...also new o2 sensors but thats all i have
so like i said it ran fine with all the mods then all the suddin it was running like ****....and i cant remember if it was messing up before or after i put the 6AL on but i know i have it on right...
D
Daggar
3,902
  • Sep 20, 2005
Ahhhhh... that helps. My first suggestion would be to pull the MSD out of the loop and reinstall your stock ingnition. If there's not change then you may want to start looking into things like possible vac leaks, bad MAF sensor, broken or loose wiring, and adjsutments in your IAC and TPS sensors.
89gt40lx
Orlando Florida
Sep 20, 2005
  • Sep 20, 2005
i have a brand new 70mm pro M calibrated for my 24lb injectors...ill try to take the msd off and i cleaned out my idle air control valve..could it be my stock fpr???
89gt40lx
Orlando Florida
Sep 20, 2005
#10
  • Sep 20, 2005
  • #10
i didnt know you could adjust or iac or tps
D
Daggar
3,902
#11
  • Sep 20, 2005
  • #11
Well you can CLEAN the IAC and adjust the TPS. After the car is good and warmed up, it should read .94 +/- .04 V on a DC voltmeter.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
