Car won't go in reverse :(
  • Thread starter Thread starter AxlsDemocracy
  • Start date Start date Dec 17, 2004
A
AxlsDemocracy
50
  • Dec 17, 2004
ok, here goes, after a few days of what sounded like extreme brake grinding, tonight, it decided to go clunk clunk and then not go in reverse. all other gears are just fine, but reverse is crap. it will move maybe 5 feet and then just stop.
whats everyones opinion on this? wheel bearing? transmission? frozen brake?
HISSIN50
34
129
Dec 17, 2004
  • Dec 17, 2004
what trans do you have, stick or auto?
A
AxlsDemocracy
50
  • Dec 17, 2004
it's an automatic
BlooDReigN
283
Calgary, Alberta
Dec 17, 2004
  • Dec 17, 2004
My car does this aswell kinda. I gotta put it in 5th and then SLAM it in to reverse. It doesn't always go in, and it ain't pretty, but I gotta keep doin it til it goes in. Some times I have to put it in the other gears like 1st, then to 5th then to reverse. Gotta go to 5th though so I can get enough speed built up to throw it in
Was easier with my stock shifter because I had more leverage. The pro 5.0 made it a bit more difficult.
HISSIN50
34
129
Dec 17, 2004
  • Dec 17, 2004
Blood, that is somewhat normal (to your degree, i dont know). when putting it in another gear, it slows the cluster down, allowing engagement into reverse to go easier.
ok, automatic issues: tell more about the brake situation - you lost me on that. has the TV cable been adjusted lately? fluid level checked?
give more info - i originally thought it was known to be a trans issue, but with your newest post, i am not sure.
good luck.
A
AxlsDemocracy
50
  • Dec 17, 2004
here is where the brakes come in, for the past few days, it had been grinding, just normal noise i would expect when it was time for new brake pads, and i was putting it off for a while. thats why i think that the brakes or brake has seized on that one rotor. if it helps any, when trying to back it up, one wheel will spin while the other holds tight, like it's braking
HISSIN50
34
129
Dec 17, 2004
  • Dec 17, 2004
please dont take this the wrong way; i know all about not having fun money. but brakes are about as important as it gets. let alone that driving with no friction material left is gonna make a 30 dollar or less (in parts, pads or shoes) turn into much more when replacing rotors, drums, etc.
the clunking could even be your rear end shouting at you for having one side locked up - i dont know. i would address that first and then figure out the rest once that is done.
as i think Michael once said, (thoughts crudely paraphrased): beg or borrow money to get the brakes fixed. one simply cannot put it off.
i dont mean to come off like a jerk - you might save some money in the long run by not chewing up other parts (if it is not too late).
and of course, i would advice NOT DRIVING THE CAR UNTIL THE BRAKES ARE BACK TO 100%.
good luck bud.
A
AxlsDemocracy
50
  • Dec 22, 2004
my ford is possessed
ok, after staring at it in the driveway for 2 days and getting bored with the jeep, i started my car up to see what it would do...it goes in reverse now, lol
so my guess is, when the brakes get hot, the caliper is locking up, does this seem right to everyone else?
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
