Car won't restart hot!!
PayUpSuka
18
DEAD cold start, it'll fire/run on the first crank. It'll stay running for however long I want, will not die. Car pulls decent, doesn't seem to be down on power. IF I shut it off, it will not restart. Almost sure I'd have to let it sit overnight before it'd actually start again. I did get the car to restart once while someone was towing me and I bump started it.
I checked spark, and it's got it. Both at the coil and each wire. It's got fuel pressure, plenty of it to run at least (42psi at the schrader valve).
List of what I checked:
- Fuel pressure = fine
- Base timing = fine
- Compression = fine
- Injector's pulsing = fine
- TPS volts = fine
- Starter = fine
- Battery/grounds = fine
- TFI module = fine
I'm really at a lose of what it could be.
Here's a quick break down of the car:
'88 Coupe with '90 5.0 shortblock, fresh GT-40 heads, E-Cam, Explorer intake, PMAS Pro-tube MAF, 42lbs injectors, 255intank pump plus t-rex pusher, custom built 70mm turbo kit, A9P computer with SCT flip on a custom dyno-tune.
Any help would be great, kinda miss driving my car..
Did the tune reduce the cranking fuel? You'd have over 100% more fuel delivery than the EEC assumes and it could create issues with warm/hot starts.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 05-Aug-2010 to add check for distributor timing in paragraph 6C.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Maybe a bad ECT?? If it happens again, maybe you can get it started by pressing down on the gas while cranking and see if it starts.
Have you checked for codes?
I had this problem before. What fixed mine was a short 2 guage ground wire from the starter to the k member. Give it a shot, it sounds very similar to my situation. What kind of Headers are you running?
Does the starter drag when you crank it or does it just crank?
Wondering the same thing. If your starter drags when it gets hot, (and possibly your wiring gets hot enough to smoke) odds are it's a bad ground. When heat goes up, so does resistance. Clean all of your ground wires, even if they look good, take them apart and scrape/wire brush until you have shiny metal. Especially the ground on the front of the engine on the timing cover (?). It's a favorite spot for galvanic corrosion.
If your starter turns free when you crank it, how did you detemine your TFI module is good ? The Autozone/Advance test is usually done when the unit is cold. Both of these things are a result of heat soak. Do you have plenty of heat sink grease under the TFI ?
maybe ignition module? does it back fire when it gets hot??:shrug:... mine would run like a champ til it got hot and i switch dat out and ran cherry:D
It's not the TFI, I have 2 spares both work (been used in other cars)
Car was driven a while with the same tune, I don't think it changed at all.
No codes. Yes, i've even checked. It won't start like that either.
Cranks normal, doesn't drag at all.
They are reverse shorty headers for the turbo. The 3inch down pipe is sorta close to the starter, but it's a new mini starter. The down pipe is also heat wrapped.
If the starter is turning over fine and the TFI is good, then my money is on fuel starvation. And with a turbo I would imagine there is even more heat under the hood. With fuel injection vapor lock is supposed to be a thing of the past, but... How's the fuel pressure look when the problem occurs ?
Sitting at 42psi. Noid light shows injectors pulsing, and the spark plugs are wet. So the car is getting fuel to the cylinders.
I'm determined to think it's a electrical/spark problem.
starting
after you start the car it runs till you shut it off,than it wont restart...
what happens if you just shut car off and try to restart without letting car sit for a couple of mins?
my thought is you say plugs are wet ,maybe its still getting fuel after you shut it off and its flooding,
maybe try another set of plugs when it wont start hot and see if it starts hot with a different set of plugs.vs waiting for it to cool down
Ive tried restarting it seconds after shutting it off, still won't refire.
do the cranks but doesnt start checklist that was posted in this thread
I did do it, the fuel side is there. I've sprayed starter fluid into the manifold and nothing, not even a sputter.
ditto...everything else is just guessing.
See above.
Most people that say they did the checklist and didn't succeed really didn't do all the checklist...
From the Cranks OK, but No Start Checklist for Fuel Injected Mustangs
