Car won't start and run when cold
jimilane
158
Raleigh, N.C.
1990 Mustang
Funny thing, it will start and run when it's colder outside, about 40 degrees. I replaced the intake temp sensor. That didn't work. I have replaced the Coolant temp sensor. That didn't work. I have replaced the ignition module. That didnt' work. I have cleaned and inspected the "salt and pepper" shakers. I have replaced both O2 sensors. That made it run better, but it's still not running when you crank it for the first time, unless it's cold outside. It has an E cam. It runs and idles fine. It has an H pipe with no cats and flowmasters. BBK shorty headers. That's all the mods.
I think i have this car running right, and then this not starting when cold, unless it's cold thing comes in. Cleaning the salt and pepper connectord helped before. Maybe it's in the wiring somewhere, but I've checked all that with a meter.
The computer is seeing correct values from the coolant and intake sensors. Well, at least the harness right before the computer is seeing the correct values. Maybe the computer connector isn't working right.
Any ideas will be appreciated, ANYTHING!!!
p.s.- My other car that's in my profile was doing the same thing once. It was an O2 sensor that corrected the problem. I know that the computer doesn't look at the O2 sensors on start up, but that's what fixed the problem!
Thanks,
Jim
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 18-Oct-2006 to include TFI fault during crank/run cycle
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
I'm somewhat confused by your wording. Are you saying the car won't start when the engine is cold unless it's cold outside?
Yep, that's it. It has to be cold, below about 40 degrees for the car to keep running after start. The car will run for 2 to 3 seconds and then die, when above about 40 degrees. The sensors I'm using are from Advance Auto/Auto Zone. Maybe that has something to do with it. I have had problems with their electrical parts before...distributor caps especially!
It doesn't take much to keep it running now. I just have to play with the gas pedal a little, and it won't die at any time. I got this far by replacing the O2 sensors, both were slow to respond, but not throwing codes. I replaced bothe and then I could keep the car running with the gas pedal. Before, you couldn't keep it running in any way.
When the car is started above about 40 degrees outside, it takes a while for it to idle right. It has to get warm enough for closed loop for everything to work right. I have replace the coolant sensor. I might just get a Ford part and see how that does.
Thanks
Jim
