Car won't start, need some help.
  • Thread starter Thread starter FrumRoll
  • Start date Start date Mar 29, 2006
F
FrumRoll
38
  • Mar 29, 2006
Took the car through the carwash today. Well it stalled while I was still in it, this isn't to unusual as it happens from time to time while at idle in gear. Started it back up and made it roughly three blocks when it stalled at roughly 30mph under load. I have never had this happen before. Figured there might be some moisture in the distributor, so I pulled the cap but no luck completely dry. I checked for spark by pulling a boot and grounding with a screwdriver, it tested positive for spark. I didn't have a gauge but I pushed the pin on the schroeder valve and I seem to have adequate fuel pressure. I have since changed the fuel filter and swapped TFI modules, plus batteries all with no luck. I'm at a bit of a loss now, the engine turns over with ease but refuses to fire. I'm hoping someone can help me. Also does anyone know how that killswitch in the hatch works, when I go to start the car the pump does prime so I'm assuming this isn't the issue but like I said I'm not real certain how it works. Also of note is that on attempted startup there is a single click from the general area of the ECU, I haven't had time to pinpoint it and I honestly can't say whether it always did this or not but I thought it should be noted. If any of you have any ideas that could help me please share. Thanks in advance.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 29, 2006
  • Mar 29, 2006
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
F
FrumRoll
38
  • Mar 29, 2006
Just an update, I sprayed some starting fluid(Ether) into the intake manifold and was still unable to get it to fire. I took a look at the gray and white harnesses near the rear of the intake, and I found a wire that seemed to have melted or shorted I also fixed that and still no luck. According to your sheet I should be at step 4, well no amount of throttle modulation gets the car to run, neither ignition or cam timing have been screwed with. The firing order is certainly correct and the car doesn't start when it's hot or cold. How very unlikely is it to be the computer, and could the carwash be related. I'd hate to blow a computer each time I go through the carwash.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Mar 29, 2006
  • Mar 29, 2006
TFI...?
F
FrumRoll
38
  • Mar 29, 2006
srothfuss said:
TFI...?
Replaced with a known working in the original post, unless I have something ruining my TFI that's not it. Thanks though.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 29, 2006
  • Mar 29, 2006
The coil is suspect at this time. Mine died while driving down the interstate, and I coasted down a off ramp and into a parking lot. I have seen coils spark, but they didn't have a nice fat blue spark, and the car would not start.
F
FrumRoll
38
  • Mar 29, 2006
Well I replaced the coil, took one off of my buddies '89 with no change, installed my coil in his car and it fired up instantly. So we switched it back and that's how it sits for now. This time out I noticed that while it's cranking(but not starting obviously), the fuel gauge goes up. It shows half a tank, and rose to 3/4 before I stopped cranking. At which point it fell back to half. It gave the impression that it would've risen all the way to full if I had cranked it over long enough. Not sure what that means if anything.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
