car wont start when warm ..until it cools
mr5o
931
Ontario, Canada
when i drive my car around alot sometimes i go to restart it and i just cranks and cranks ...leave it for a while 30-45 min then it fires right up ....new fuel pump and distributer and coil ...anything i should check
Working on the same problem here. If I hold the gas peddle all the way down while cranking it will start. We have similar setups so could be the same issue. I am begining to questin the MSD boxes if that has anything to do with it. I dont think mine is getting to hot because its under the driver seat. Im going to pull codes sat and I will let you know what I find.
As I am sure you know, holding the gas pedal while cranking cuts the injector pulse (helps with flood conditions).
good luck.
with mine I have the stock dizzy still, I was going to get the MSD pro bullit in june but i dont know now. In my case I can smell raw fuel but It will start if I floor it which cuts off the injectors so maybe too much fuel? I dont know. Like I said I'll pull codes and let you know
mr5o said:
i can hear the pump kick on ....whats the best way to check the spark
take a spark plug wire off a plug. grab a spare spark plug off the bench (i keep old plugs around for this) and put the old plug in the plug boot. set the old plug on the plenum with the threads touching the plenum (ground). crank and watch for a spark to jump the plug gap.
also, just because a pump primes does not mean it is delivering pressure or volume. A diagnostic fuel pressure gauge is a must have, IMHO, in one's tool box. 20-30 bucks at the parts store. it screws onto the schrader valve on the [pass side] fuel rail.
good luck.
Nick - I knew you meant to toss that info in there. :)
Thats really weird, because I get shocked to. Maybe a bad ground some where? Don't think that would effect the warm start though. Can you start your car if you hold the gas down when its warm. If its not the first thing I do it wont start untill it cools.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
