  • 1994 - 1995 Specific Tech
Car Won't Start!
  • Thread starter Thread starter xYoung347x
  • Start date Start date Jan 9, 2004
xYoung347x
382
  • Jan 9, 2004
Just put a 347 into a 94 GT and converted it from a auto to a tremec. We put in the manual cpu and tranny harness. When you turn the key the fuel pump will primer and it has fuel pressure and the starter will kick out but the car will not turn over. Do you think the starter could be bad kick out but not engage to turn the motor over? If the distributor was stabbed wrong could that be the problem? we check all the fuse and everything but Im still stump. Am I missing something?
2L8ULUZ2
Will kiss Moderator ass for title
3,033
14
99
WNC
Jan 9, 2004
  • Jan 9, 2004
What is the compression of this current motor? If it is higher then it could show that your starter or battery is weak. If it's too high then you might have to get a higher torque starter and a stronger battery. If it is kicking out then it's working but not turning the motor. If it turns and does not start then it could be your distributor but with it not turning at all I would look to the starter/battery first.
xYoung347x
382
  • Jan 9, 2004
I have a Duralast battery and Im going replace the starter tomorrow but please keep coming.
P.S. the compression SHOULD be a round 9.7 to 9.8!
2L8ULUZ2
3,033
14
99
WNC
Jan 9, 2004
  • Jan 9, 2004
Well with it being around 10:1 compression a stock starter should turn it over just fine if it's in good shape and so is the battery.
xYoung347x
382
  • Jan 9, 2004
the battery is full charge and I will change the starter today, anything else beside the starter and the battery?
xYoung347x
382
  • Jan 9, 2004
Ttt
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
