I have a 1990 lx, all stock. I parked it for 5 months for winter. It started first try everytime every 2 weeks all winter long. When I took it out on the road the first day this spring, the battery died when I turned off my car. I boosted it, and it worked fine. Then the second day I drove it the battery died again and I couldn't start it, even boosting wouldn't work.
So today I replaced my alternator, and charged my battery up. I had my battery tested and they said it was fine, just needed to be charged. So I just tried to start it, and it wouldn't start. I even tried boosting it, wouldn't start.
Now this is what is happening is when I reconnect the battery after charging it:
Put the key in the ignition and turn it half way so that the dash lights come on, which works fine. Then when I turn the key to start it it just clicks, the engine doesn't try and turn over or anything, no engine sounds whatsoever. I hear my fuel pump working when I turn the key, so I don't think it's that. I also hear a click, so it couldn't be my starter right? What's weird is that the dash lights will only come on until I try to start the first time, then when I pull the keys back it's like the car completely shuts off, won't let me try to start again unless I disconnect the battery then reconnect it.
So I guess it's something electrical? Any suggestions? And where is the link to that website that tells you how to pull error codes? I can't find it in the forums. Thanks.
Glad to hear you got it sorted out. Looks like you need a couple new sensors as well. I'd also make a separate post dealing with those computer error codes and make sure there's nothing there that will give you any trouble.
