Carb or Injected?
R0B3RT(63B)
Which in your opinion is better for an everyday driver? carb or fule injection? sence i have a 1989 GT 5.0 is it possible to sitch to carbed if i wanted to? and about how much would it cost?:shrug:
The 89s were MAF weren't they?
The benefits of a carb on a daily driver will be minimal. You will NEVER pass emissions with a carb, if that is a remote concern.
Think of a carb this way...
With a carb you can select 1 of the following
Peak Power
Minimal Emissions
Peak Fuel Economy
OR make a level compromise of all three.
With fuel injection you can pick 2 of the above, or have a better compromise of all three (compared to what would be expected with a carb).
EFI will adjust for a lot of things that will make driving the car more enjoyable, such as air temp, coolant temp, and atmospheric pressure (elevation changes).
All of these things will affect the fuel metering, and spark advance. Most carbs can't do that.
Your efi setup (even if it is stock) is pretty good. Unless you are building an all out drag car, your better off with efi.
As for the cost of conversion.
If you had to replace every sensor for the computer, and all of the emissions stuff it would probably be about a wash. Just a guesstimate on my part though.
My opinion,
jason
