- Feb 15, 2007
- 20
- 0
- 0
Engine specs are listed in my sig. I have a problem with running rich. Dark smoke at idle and fouled plugs. Anything after 3000 rpm is no problem. But at idle and when i first hit the gas it smokes. I did a compression test to make sure no problems with rings or valves. All cylinders were between 180-185 psi. The HP 750 comes stock with a 6.5 power valve. Holley said to take vacuum reading @ idle and divide that number by 2. My vacuum at idle is 5.5 psi so i put a 2.5 power valve in and still have same problem. Never had any problems with car idling. Rpm at idle is around 1000-1100. The car runs great and is very fast. But is burning so rich at idle it makes my eyes water. Even with the set-up it is not bad on street, have never at it cut off on me. Trying to fix what i can before i get a dyno tune. And i am not sure that will help my rich problem. The car was built to scream but cant always do that on the street.
Thanks
Thanks
