carb question, think im running lean
85-302
74
st petersburg FL
i checked the plugs on it jut for the hell of it and it looks like there are small white dots comeing out on the electrode i think that means its running lean. :nonono: im running one step colder plugs, autolite. allso the metal portion which curves up above the plug is turning white.... if it is running lean how do i adjust it. thanks
its been running fine, really strong. i use 93 oct. the dots arnt that noticable i just was hopeing i could catch something before it got started. oh and i just had the top of the engine rebuild w/ mild head work new carb(holly 650) and cleaned everything up real nice. i also have full exhaust and some other bolt ons. thanks for the comptement... i want a car like yours. workin on it :nice:
To adjust the mixture, you have to open the carb and install larger jets. You can get a whole box of jets for $30 or so from jegs. You would want to go up one or two at the most. It is common for carbed cars to go lean in the winter with cool dry air.
