carb throttle cable bracket???
Im just finishing up my efi to carb swap I picked up a new throttle cable for an 85gt and got it all in but now i need a throttle cable bracket. Im running a rpm airgap manifold with a modded 3310. Where can I get an oem ford bracket or even an aftermarket bracket that doesnt fit under the carb? This is one of the last things holding me up from getting it running! Any help would be appreciated!
Thanks in advance
I'm no sure what you mean by a bracket that doesn't fit "under the carb", but this is a good bracket.
It mounts on top of the carb base, between the carb base and the rear drive side carb stud nut.
Lokar SRK-4000, includes throttle return springs.
Jegs
Jegs sells a real nice billet aluminum ajustable bracket and a stainless steel braided throttle cable. This is what I have on my 1991 coupe with a carb conversion.
