carb'd 90 notch ignition problem???
  • Thread starter Thread starter sickstang88
  • Start date Start date Aug 28, 2007
sickstang88
14
new jersey
Aug 28, 2007
  • Aug 28, 2007
i have a carbureted 90 notchback it has something going on with the ignition, in the day time it seems like a miss but at night you can see a spark jumping across the terminals on the coil and you can see a spark traveling all the way down each sparkplug wire from the distributor all the way to the plugs is this normal? the wires are brand new msd wires and brand new bosch platinum plugs msd blaster 2 coil and mallory unilite distributor. now i changed the coil and it ran decent for about a week then it started doing the same thing? its driving me nuts.. can anyone help? could it be a bad ground or something? the only ground i have is from the battery to the engine block. do i need a ground strap from the engine the the chassis?
SmockDoiley
1,591
San Diego, CA
Aug 28, 2007
  • Aug 28, 2007
Regardless, you should always have a ground from the engine to the chassis. Being that you have such a hot ignition, that could likely be the problem. You should also try Corral.net because they have people that actually answer questions.
1Bad88notch
62
Leesburg,FL
Aug 28, 2007
  • Aug 28, 2007
you could have a bad ground or a bad ignition box. same thing happened to me bothered my for a week and found out it was my msd ignition box going bad
sickstang88
14
new jersey
Aug 29, 2007
  • Aug 29, 2007
i already bypassed my msd box before i changed the coil and it still fried another coil. im gonna try grounding the engine to the chassis tonight
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
