Carburator problem
  • Thread starter Thread starter XR7_351C
  • Start date Start date May 21, 2004
XR7_351C
47
  • May 21, 2004
Hi Everyone
I have a Edelbroke 1406 600CFM carburator with the Edelbroke
aluminium intake on my 351C 1970 XR7 Mercury Cougar
Latelly it's been causing me some problem with the gas staying
partially stuck if depressing the accelerator slowly, it can run
anywhere from 800 RPM to 2500 RPM, while I adjusted the idle at
roughly 500-600 RPM
It does not do it when it's cold i.e. when starting the engine or
after a few minute even while it's reaching operating temps. It
does it after a good ride. The car was not run during winter except
started every mount for about 30 minutes.
While the gas is 'stuck' and trans is in Park if I kill the
engine the throttle immediatly goes back to 'zero' position. If I
move the throttle by hand directly on the carburator I can feel the
resistance in the throttle plate and this resistance vanishes
immediatly when the engine is off even if it's fully warmed.
When trottle cable is disconnected, or Electric choke is powered or not, made no difference.
I must admit I'm truly puzzled by that...but since my knowledge of
carburator is limited, maybe someone can point me in the right
direction...I can give it a good clean...but i'd rather know what
part of the carburator to give more attention too.
Thanks in advance for your suggestions.
Ghislain
Montreal, Canada
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
May 21, 2004
  • May 21, 2004
I do not understand whay you are having this problem. I have been using a carter carb for like 4 years now. It is the same basic design as the Edelbrock, and although I have had problems, I have never expeirenced one like that. The throttle getting stuck only when the engine is on is a wierd one. The only things that I can think of is either the throtle plates are binding on the housing, or the little cam inside the choke housing is binding and needs to be cleaned.
Max Power
1,774
St Paul
May 21, 2004
  • May 21, 2004
LOL at "Edelbroke".
Pun intended?
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
