Carrier bearing install ? Rear axel bearings ?
Carrier bearing install? Rear axle bearings?
Well it looks like I need to replace my carrier bearings, I just replaced the axle bearings and it did not help with the grinding sound coming from the rear end of the car. How hard is it to take apart the rear axle? Can this be done with out too many special tools? I need to basically replace all the bearings possible. Thanks
You'll need a two-jaw puller to remove the carrier bearings, and a press to put the new ones back on. You can rent the puller for free at Autozone (also rent their master bearing installer kit - it has an assortment of alum discs, one of which will fit on top of the hole to provide the puller with a base to press against). I have a press and I'd be happy to press the new bearings on for you.
