Cars running hotter than usual
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Well i started noticing lately that my car is running about 10 degrees hotter than it usually does. USually it stays around 195 or so, lately its been getting up to 210 or higher and i know its not the temperature outside because its been getting cooler. I just changed out my radiator fluid a few months ago and the resevoir is full.
could my thermostat be sticking? What could be the problem..
oh and i replaced my water pump a few months ago as well and im getting my temp readings from an aftermarket gauge so i know its accurate
Throw in more water, or water wetter and be happy :).
Did you used to use the AC and since the weather started getting colder, yu stopped?
Is this at cruising speeds, traffic, what?
this is at any time, i mean when i start going a steady speed it cools down to about 205 or so but when i stop it goes back up to 210+,
you have to understnad for the year ive owned it its never gone above 200
also its got plenty of coolant in the reservoir
Only thing i can think of is maybe the thermostat is giving you trouble or that new water pump. I know its new but sometimes new stuff will fail in like a month to six months.
deftsound said:
Replace the therm. and put water wetter in the coolant.
You can also use a tuner to run the fans more often...that would definetely cool her down.
If that stuff doesnt help, your water pump could be taking a sh1t.
And I doubt its a head gasket problem cause your car would be blowing white smoke all over the place by now lol.
I bet its the thermastat.
deftsound said:
im thinking the thermostat must be sticking a little or something bu till try burpin it
Derek brings up a good point...if you installed your water gauge sender at the therm. housing your gauge might be slightly off. Some people installed the sender at the top/side of the therm versus towards the bottom, and their gauges weren't reading accuratetly. Unless of course you installed your sender on the drivers side plug on the block....then your gauge should be accurate.
no i installed it on the drivers side of the block down at the bottom, not at the thermo housing
heres pics incased your interested
attachment.php
I've had some recent cooling troubles myself, and found that even though the cooling fan was plugged in, the plug itself had cracked causing one of the three connections to make / not make. You may get it up to temp and wiggle the wires just to rule this one out.
Just because the reservoir is at the right level, you still very well could have a low coolant level. With the car DEAD COLD, remove the radiator cap, not the reservoir cap and see if the radiator is full. If not start the cold engine with the radiator cap off and fill up with your coolant mixture then put the cap back on. Run it a day and then pull the radiator cap again when it is DEAD COLD and repeat the process if necessary.
Since reservoirs and warnings on radiator caps, it is all too common to see cars with low coolants and the owners say that they are not supposed to remove the radiator cap because of the warning label on the cap.
You can remove the cap with a warm engine lol. Just have to use a rag and let the pressure out slowly. However I wouldn't recommend this to anyone lol. I'm just really impatient so I do it the "dangerous" way.
