Casper Electronics Throttle Enchancer
  • Thread starter Thread starter crunchie12268
  • Start date Start date Dec 16, 2004
C
crunchie12268
599
Manhattan, KS
Dec 16, 2004
  • Dec 16, 2004
This is in the summit catolog and I was wondering if anybody has it or have heard of anything. The Casper Throttle Enchancer only cost like 90 bucks and says that it will increase throttle response. But does this mess with anything? If your timing is already at 14*? Thanks for your help!
88 Fox GT
1,674
Iowa
Dec 16, 2004
  • Dec 16, 2004
Says it plugs into the TPS and eliminates throttle hesitation. I haven't experienced any hesitation when stomping the throttle down. Only slight lag, as it is a MAF system. I don't think it's worth $90, unless someone here has had first hand experience and thinks it really helps.
C
crunchie12268
599
Manhattan, KS
Dec 16, 2004
  • Dec 16, 2004
Yeah.... sounds like a simple upgrade and could give you some on tap power. Does anybody on here have it?
M
matm347
2,056
  • Dec 16, 2004
All it supposedly does is when you are at 60% throttle or above, it tells the ECU that you are at WOT(in the form of WOT voltage). To me, this is not worth the $$$ at all. A properly tuned car shouldn't hesitate at all. No extra power will come out of this either.
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
